Janniklindskov
- Sep 13, 2009
- 44
Hello There...
Hope you understand my english, if from Denmark so it is not the best...
I just got my old 1986 90 hp V4 Johnson started up today on the muffs.
It startede right up and It idle fine but sometimes it had like a little stumble, not acturly a misfire. I would idle and then drop in RPM and after 1 sec it will get back up again to normal idle. The funny thing is that the water peeing got hot when it had these stumbles. The peeing is realy strong.
Last summer it had these stumbles, but not the thing with the peeing gettng hot. Because of this I rebuild the carbs and cleaned them this winter - I used BPR parts.
The stumbles is only at idle, it will go through the trottle range with no problem an get my boat on plane very easy, and run great on WOT.
Well back to the problem..... - After a few mintues with this stumbling and the water getting hot, I stoped the engine and just gently hit the thermostat housing to maybe get them to open or something..... After that i started it up again and then the stumblin was a lot less, i could just see the engine sometimes just shake a little. The peeing was also not hot.
When the engine was running i noticed that the rightside(in the sailing direction) of the engine was a bit more hot then the left. Could not hold my finger on either side because it was to hot.
Here is what i have been doing this winter - fresh fuel, all new fuel lines. Rebuild carbs, new throttle cables. I know i haven't done a compression test og spark test.
I dont know what the problem is, in my opinion if it would be electric the problem would be there all the time, but this is just coming and going.
Hope that anyone can give me a clue on where to start....
Nest time i will have it on muffs i will make a video og the engine running and then it is easier to see.
Jannik
Jannik
