1986 Johnson GT150 J150STLCDC.
Getting ready to replace the water pump on this motor and was wondering if it would be a good idea to replace the upper driveshaft seals at the same time. There is no indication of them failing, but thought that while I had it apart I might as well replace any seals that I could easily get to. Is this a simple remove the 4 upper bearing housing bolts, slide it and the seals off drive shaft, replace two oil retainer seals and O ring and reinstall, or is this one of those jobs that falls into the "if it aint broke dont fix it " category. Also if there is any other recommended maint I should perform while I have it apart please let me know.
