Blake0912
- Oct 31, 2010
- 310
My 9.9 Johnson is leaking a heck of a lot of burnt oil/gas from the prop , the inside of the prop is covered with it after I run it on my muffs. I don't use this motor much in the water since its my kicker and I don't want to run it all the time in saltwater for no reason.
I checked the gear oil twice and it had no indication of water intrusion and the stuff coming out of the prop Deffineatly smells like gas but it's dark brown With a hint of blue ( oil color ).
My first thought was I had taken it to a machanic to fix the rope start and he ran it in a very dirty test tank so I thought it had sucked up a lot of dirty / oily water but I've ran It for about 30 mins pushing the boat around , and also on the muffs I start it up every weekend before I head out.
The motor runs fine and starts on the first pull , I can even start if by spinning the fly wheel by hand. Is this normal for these motors to leak that much oil/gas out of the prop or is this a sign of some gasket going bad ?
