Re: 1985 procraft 1680 v 115 hp starting issues please help
If the plunger moves at all, then the solenoid is probably good. Clean inside the solenoid and the plunger with a clean dry scotch-brite scrubby pad, not too hard, but enough to make sure any crustys are gone and that the plunger can freely slide in and out.
Check the linkage on the shutters, clean if necessary, ensure that they move freely enough that they FALL back to the open position of their own weight. The solenoid pulls the linkage UP, there is no return spring or anything to push it back down other than its own weight.
It is a very basic choke for the upper 4 cylinders. Adequate to start the motor when cold.
