Bonstrosity
- Jun 7, 2006
- 48
I have the motor stated above that will not idle. It will start up and run at about 1/4 throttle, just before the timing gets advanced above the carb but it will not run any lower. I have replaced the plugs, rebuilt the carb, and rebuilt the fuel pump. I just can not seem to get it to idle. I have the idle adjustment anywhere from 1 to 2 turns out from the bottom and it does not seem to help.Next I will be testing the compression to see if that is the problem. Any other ideas would be great.
What happens is when I turn the throttle down it sputters, runs for a little bit and sputters, then after about 2 or 3 times it shuts off. To start it back up I need to pump the primer on the motor and it'll fire right back up at 1/4 throttle. Any other ideas?
