We recently bought a used pontoon that has a 1985 85 HP motor on it. Yesterday was the first time we have taken it to the river. When I first fired the motor up, it popped and sputted like it had water in the gas. (it was hard to fire up) I know it didn't have water in the gas as I just bought the gas (not ethanol). The motor will not low idle, I have to keep the idle lever all the way up to keep it running and the only way to put it in gear without it dying is shut the idle down and just before it dies shove it in gear. Pretty tricky timing to keep the gears from grinding.
While it did run while giving it gas, it would die if the rpms got too low. It never opened up past half throttle, that was about as good as it got. I did take the carbs off and cleaned them with brake cleaner and blew them out. The carbs weren't too badly gunked up so I thought I was good to go. The needles looked to be in good shape also and all gaskets were rubber and in great shape.
Are there any adjustment screws on these carbs? I have another 85 HP Johnson that ran great when I parked it, maybe clean the carbs from that one might work. Also, we went about 4 or five miles down the river/lake at a low speed and we burned about 5 gallons of gas, is that normal? I haven't checked the compression yet but I will get a gauge and check.
Would seafoam help any?
