I've got this 35 HP that unfortunately ate some metal piece, that got into it. One of the cylinders has 3 very small scores, a little chip on edge of a port, and head is banged a bit, one piston damaged at ringlands. I've got 2 used pistons from ebay. Bores are 2.995 and I plan to hone them a bit and round the edges in intake ports. I am not able to measure bores out of round, cross-pattern still intact, this motor sat for years with a bad lower unit. The used pistons measure as follows at skirt: parallel with pins, 2.990, 90 deg to pins, 2.988. How is that, will I be fine with the hone and rering job ??
