Bill Collector
- Feb 27, 2005
- 79
Please excuse any mispellings I'm on my phone. I found a cherry in a barn in nh. Original owner, no salt water, kept indoors it's whole life and no salt. It sat 4 years and before that had very little use. I drained the tank and removed and cleaned the csrbs. Bottom carb was packed with crap. Reassembled and used the boat 5 times with little issue besides the idle. Boat runs strong and is fast and smooth throughout shifting and throttle range. After it's warm it won't hold an idle and I'm noticing gas in N the water around the engine. Enough to be concerned with. I trimmed up the motor and gas leaked out of the carbs so I know that's a problem. Carbs are jetted 1.5 turns out. Once warm it will start if you put it in neutral and goose it while cranking, then have to Rev it and do the quick move into gear. Will run like hell after that but I need to fix this. Bought 3 carb kits and carbs are on my bench waiting for rebuild. My question is are my symptoms in line with leaking float valves? Ie - need to rebuild them.
Of note- new bulb, new plugs, new gear oil and compression is great.
