JoshKeller84
- Jul 2, 2010
- 220
j75ecrd
j5949958
rebuilt the engine, and starting breaking it in and the compression evened out pretty well. I left for 4 days for a bear hunting trip, and came back and am having a no crank condition.
wire directly from battery to starter works fine.
getting 12.7v to the hot wire on the solenoid.
get 12.7v to the yellow wire on the solenoid when key is put into crank position.
no power to the out wire on the solenoid.
primer choke does work, so im getting power.
tried two wiring harness/key switches to eliminate bad ignition switch/neutral safety switch
tried three solenoids (one brand new) to eliminate bad solenoid. The other solenoids work on my other motor.
any suggestions on what to try next?
j5949958
