Here's the problem: motor was running rough so I replaced the spark plugs. I started the engine, ran for a little bit, it revved high and then quit. After it quit I noticed that the fuel line to the bottom carb was leaking profusely, which I believe was my problem all along. I fixed that problem and now the motor won't start at all because there is no spark to any of plugs (used a spark plug tester I bought at autozone that tested good on a little Johnson I have).
I tried the procedure outlined here by Joe Reeves to test for a bad ignition switch:
1984 Johnson 70 hp No Spark
And still no spark, what next?
