Hi, I had my 17 ft Whaler out the other day and it was running fine. On the way back to the ramp I noticed that the sea cork had fallen out and when I went to put in a spare (with the motor in neutral) I was getting a shock when I put my hand in the water; is this normal? Luckily I was able to plug the drain from the inside boat and the bilge pump cleared the water, but after that the motor kept stalling out when at a low idle. I'm not sure if the 2 events are related but I was hoping someone could shed some light on the issue.
