I'm re-installing my trim & tilt pump and motor after repairs, and want to flush out the old hydraulic fluid first. I removed the fill plug and the allen plug under the reservoir but the fluid only dripped a bit and stopped. I figured there might be some debris blocking the drain so I pushed a pipe cleaner up the drain hole. That didn't do anything so I tried to open it up using an air compressor. It still didn't empty.
Is it possible that the trim rams need to be extended ir order to drain the fluid? They are not extended because I had to raise the motor manually to get at the reservoir.
Any help or comments would be appreciated.
Joe
Joe
