1984 75hp mercury 4 cyl stator replacement
axiosteve
I'm going to replace my stator. I would like to find a good downloadable manual or if someone can post a picture of the process from there's or give me a play by play
Bt Doctur
Re: 1984 75hp mercury 4 cyl stator replacement
your in the I/O section but that s ok.
remove crackshaft nut, use proper puller to remove flywheel. remove mounting bolts R/R stator, reassemble NO BIG HAMMERS
If you dont have the correct puller, loosen cranknut to top of threads,but do not remove.
carefully raise up the flywheel and using a wood block give the nut a sharo tap, this shouold free the flywheel DO NOT LOSE THE WOODRUFF KEY
you`ll find your manual in here http://boatinfo.no/lib/library.html
axiosteve
Thank you for this inforation. Will i be running into any timing issues ? the flywheel has markings on it and a pointer that sticks out and up next to the flywheel.
Bt Doctur
Stator is for powering the ign packs and for the charging system, has nothing to do with timing.there is a inner coil setup for ignition timing.
