1984 75hp mariner 4 cylinder cooling system
My motor is not peeing at all using muffs. I cannot find any diagrams to locate the thermostat. I have a water pump rebuild kit I am going to install but am wondering if it could be the thermostat. any help would be appreciated.
There is no thermostat on those !-------Replace impeller and clean out the hose / fitting on indicator.-------That impeller should be repaced every 3 years too.
Thank you for your response. I have the lower unit off now. could you please tell me where the indicator is located. Thanks
​ again for helping this rookie out.
