1984 70hp 2stroke yamaha lower unit swap with a 90 hp
Status
Not open for further replies.
jimbad
Hi, I have a 70 hp 1984 yamaha ETLK. The lower unit is bad. I found a 90 horsepower a similar year that I can get the lower unit from. Are these lower units compatible ? Can I use the 90's lower unit on my 70 ? If so and I do swap them is there anything I need to do other then bolt it up ? Such as shims or anything or does it just simply exchange ?
99yam40
Re: 1984 70hp 2stroke yamaha lower unit swap with a 90 hp
look up the part #s of both to see if they are the same
boscoe99
The part number for the assemblies (complete lower unit) are not the same. However,
both of the housings are the same part number. So, it is presumed that a 90TLR gear case will fit a 70TLR motor. However,
the gear ratio for the 70TLR is 2.33/1 whereas for the 90TLR it is 2/1. Therefore, you might have to change the propeller to one of a lesser pitch.
b10doyle
Boscoe99, I'm wondering if you ever ended up doing this swap? I was told that my lower unit is bad on my 1987 70hp ETLH 2 stroke, and I'm wondering if there are any other lower units that would work if I have to go the used route.
Thank you.
GA_Boater
Thank you.
He hasn't been here in a year and a half.
Closed.
Status
