I bought a 15 hp used only to discover that the lower unit drain hole was plugged with an epoxy or something , probably because previous owner stripped threads.
So I have taken off the lower unit to try to get lube in there. I pulled the drive shaft out as well. Can I fill the lube through that hole? Will it get all the way down into the gearcase or not? Do I have to pull the gearcase out?
If I do pull gearcase out is it a hard job or should it come out in one soilid piece. I wan t to avoid creating more problems for myself.
Any suggestions would be appreciated.
Thanks
Thanks
