just bought 3 new teleflex gauges for my great running "tower of power"
rpm,fuel,battery,
Reason i bought them is my old tach would not work and the needle broke.After i hooked them up My new tach would not work and so i went through the old threads on rpm gauges and found out it was my rectifier,so i changed that and it works My ? is my battery gauge reads about 13 volts at 2000 rpm's but at wot it is about 15.5 volts it is still in the green area on the tach from 12volts to 16 volts just wondering if i should be concerned about the 15.5 volts thanks
rpm,fuel,battery,
