anyone know what psi the oil pressure should be at idle..i believe my light is bad..i am getting 23psi at idle and 40 psi when i give it some gas in neutral
I looked through the manual and they don't have a psi listed. You can test the light by disconnecting the lamp wiring harness, connect the lamp wires to a 9-volt battery-if it doesn't light change the bulb. 40 psi sounds about right, but at the lower end I can't find a number-I'll keep looking.
