kevdog2000
- May 20, 2012
- 24
Hi all, my tilt/trim motor doesn't work all the time. I think the motor is bad because if I tap it with a hammer it'll start working. However, for my question, when testing the voltage I noticed that I get 12V on the blue and green wires regardless of whether I'm pushing the up or down button. The motor works correctly, meaning when I push up it goes up and vice versa. It's a 3 wire motor, blue(up), green(down) and black(ground). I'm curious if this is correct or I have an issue in the wiring.
Thanks for your help!
Kevin
1983 75hp Johnson Sea Horse
Kevin
