bigpoppakdog
- Jul 9, 2008
- 437
I've been an evinrude guy on this board for about 5 years. Just recently had to retire my 1970 rude. Upgraded to a 1983 115 hp mercury. Compression was 125 across all 6. Coils were checked and replaced for those that needed it. fuel lines from tank to motor are new. Motor starts up great, idles great in the water and has a great hole shot. Only issue is the engine sputt, sputt, sputters, then dies when just put in gear at super slow speed as you approach the dock/boat ramp. Have a tough time getting it started after it dies. I've tried to push the choke in when it's sputtering and also pushing on the fuel bulb. The bulb thing did nothing. The choke caused it to stall even faster. Again, idle is great, as soon as you pass that first 1/8 or so on the throttle when in gear there is no stall. No problem going from idle in neutral to full cracked throttle. Just a stall a short time after put in gear.
