I pulled the lower unit out of my 1982 9.8 Merk short shaft and cannot get the lower unit back in. I've had it as close as 3/4" to having it slip in and now its about 1 1/2" from going back in.<br />I'll push the lower unit in and right before it goes in completely it hits something (metal to metal).<br />I assume the teeth aren't lining up on the shift rod or the shaft that spins the prop.<br />I've tried everything I can think of to make it go back in and it won't.<br />I've put it in every gear, pulled the start rope, spun the prop around, turned both shafts, lubed it, etc.<br />Before I chuck it in the street I thought I'd see if anyone has any ideas.<br />Thanks, Jay!!!
