Hi peeps!
I have a 1981 johnson 90 ho v4 seahorse that has no spark to the lower left cylinder (#4?). i can see where the lower coil pack has gotten hot and the same goes for the top. Seals on both look "wet" and I can see some damaged wiring leading from the top coil to the lower. I repaired the wire to no avail. Still no spark.
Well I was going to swap coils from one side to another to see if the miss followed the coils, but of course when trying to remove the pin from the connector it broke. so now I need a new ignition coil.
My issue is that the top coil and the bottom coil are different. Top utilizes a 2 wire and post design and is flat like every coil I see when I try to purchase new coils. Easy to find and replace.
however the bottom coil is different and I cannot find a replacement that looks like it will work correctly.
The bottom coil is more like a barrel and has no post, just a spark plug wire/boot built directly in with 2 wires leading off. One for ground and one into the connector between top and bottom coils. How come I cannot find a coil that looks like that to replace it? Am I missing something?
