Re: 1981 Johnson 2 hp with no spark
Thanks guys.
I took the flywheel off last night, checked the point and adjusted it to the spec that was on the flywheel. It wasnt even close.
I put it back together, still no spark. Everything looked good though, no corrosion or anything else suspect. I did remove and clean all grounds anyway.
What would you do next? Replace the coil? Or replace the condensor and point?
