I have this exact setup. Everything is in order why would the port head engine temp switch be going off (meaning audible alarm its overheating)? I have removed the riser and is in vgc the manifold has slight surface rust. I have a SS block off plate between two gaskets installed with only a small hole, no flow thru. Additionally new impeller in Out drive. Pre alpha. and its not the Oil pressure and I have no lube sensor.
TIA?
TIA?
