Well, I have everything running well on this old motor...got rid of the rough idle, but now I'm concerned about potential cooling/water flow issues. I replaced the impeller several months ago, but now I'm seeing no water coming out of the exhaust leg (in the middle), only light smoke. Additionally, I'm seeing no water coming out of the small tell tale on the starboard rear of the motor housing? I'm using a 100 gal. stock tank to immerse it in. A week ago, I saw water coming out of the tell tale, but it was only after it had been running a 15+ minutes. I can hold on to the heads, and they're not that hot? Does the thermostat have to open on this model for the tell tale to operate? I'm confused due to differing opinions on the thermostat impact on the tell tale flow. My original manual didn't have a water flow diagram which would have been very helpful. I hope I haven't damaged my new impeller. Your thoughts?
