Re: 1980 85hp chrysler..$150?!
I would buy it just for the prop. That is an original one piece Chrysler prop with the cast in tailcone spacer. You don't see too many of them. Then, the tailcone is difficult to find and they go about 20 bucks used on craigs. It has a newer replacement CDI module. He is saying that controls come with it too.
The piston is not as badly damaged as some I have seen, so the block is probably repairable with an overbore.--About 200 in parts.
However, right now, consider it a parts engine. 150 is an OK price, you certainly will not get hurt, but I would see if he might let it go for a little less. It can't hurt to ask!
Back to the prop: When Chrysler first designed the one piece lower unit, they made the midleg one inch shorter. That's one of the ways they got 3 MPH more speed out of it. Anyway, for appearance, they had Michigan make that nice, streamlined prop. Michigan also produced for them a plain prop and someone made a metal prop spacer for use on these extended shaft engines with a tailcone.
However, the shorter leg ventilated like crazy on most boats and customers were complaining. So, Chrysler rushed into production a "Flare Washer" anti-cavitation washer for use on the plain prop to help with ventilation/cavitation. Even on the older Force engines, the shaft splines were kept the same length, so if you don't use a flare washer or spacer, you must use a special spacer washer to take up the excess splines at the rear of the prop--otherwise, you will not be able to tighten it and it will shift forward and back about 1/4 inch.
These engines, for this reason (ventilation) almost always do better with a cupped prop.
White props are plain hub with and without the plain metal spacer and the black flare washer. Red painted parts are the tailcone and flare washer on an open hub Michigan stainless prop.
By the way: The ignition is distributor CD so either it was retro-fit or the engine is around 77-78. By 1980, Prestolite non-distributor was standard.
