johnny whaler
- Sep 4, 2006
- 56
I have this 1978 Evinrude 35 HP long shaft on my 1963 13' whaler. It ran great but was not pumping well, I changed the thermostat. Then it ran good but seemed to suck somethign up in the carb. I had the carb off and had it cleaned. The shop said there was a chunk in the jet area and I put it back together and it ran great today for a solid 90 minutesof high speed, low speed and on and off abuse. I came WOT into the break walls and then shut it down and it started acting up all over again. Kind of like it was loaded up. It wouldn't rev up high. If I let it idle for a little while it would somewhat clean out and then rev up again but then do it all over. It got to the point that it was even breaking up on the high end.
I put it in the dock and put it in Neutral and it even took a while to "blow it out" and get the engine to rev up.
The carb was cleaned, the gas tank is brand new, the ful line is brand new BUT I did notice that the entire inside of the engine housing had all the paint bubbling up like from paint stripper but it was from the carb cleaner. I also noticed the foam insulation in this 30 year old engine was pretty much shot and easily came off in small chunks. Call me crazy but if it ran great for 90 minutes after a good carb clean and then got bad all over again would anyone suspect the foam or the carb cleaner bubbling up the paint could be the effect all along? I've done more stuff to this thing and I bet it was just a dirty inside of the engine. Has anyone heard of this? Would it really suck enough to pull some of the paint or foam inside the carb? I'm guessing if it did I need to remove the entie carb again and simply unscrewing the float drain wont do it?
Help if you can....thanks...I will take any sugestions!!!
