1978 Bayliner Quartermaster restoration
Allbutwet
Re: 1978 Bayliner Quartermaster restoration
Hey all! Sorry it's been so long since I posted any updates. I have reassemble the mid section and mated it up with the bottom section. I also put the gear box back together. I drilled all the holes to remount the Transom shield, fitted the garboard drain. had to modify it to accept the plug that is double threaded so you can open it without removing the plug completly. I will try to post some updated pics in the next couple of weeks. Hope you are all having a great summer.:)
74bayliner
Hey hope you still stopped working on the boat... but this winter has been wet so i understand. especially for you guys just south of us here in seattle area... I wanted to know that Slide Hammer.. where did you get that? and is it just a regular slide hammer with a special end that screws into the Prop shaft? please let me know... i sent you my number so text me that way the response is faster thanks. -vlad
74bayliner
i meant to say i hope you still havent stopped working on the boat... oof typing with iphones
Allbutwet
Well I received great news today. Machine shop hot tanked and maged the block. And says all looks good.So I ordered all my bearings and new pistons. Should have them next week. Will try and post some pics later this weekend.:D:D
Allbutwet
All right time for some more photo's.
Front of engine
Port side of engine. For those of you who are looking for the tag on your Volvo AQ here it is. The rectangular tag.
The Head before.
Allbutwet
Head after stripping it down.
Sorry for the size I had my cell camera set to small.
74bayliner
very nice my friend...i like the progress...
i am still waiting on the garage situation to get cleaned up... i have all the tools sockets etc in a big box and im throwing out the old ones and keeping good ones... once i have all of that then i can start the assembly..
I am following your thread and cant wait to see what it comes out to look like..
Some advice if your going to be updating your alternator.. i have read some really good reviews on here about Delco 105amp alternator. dsi alternator for 95 bucks?? you cant beat that... i know im getting it on my boat. just wanted to throw you a heads up
Allbutwet
Transom shield after bead blasting. I had already sanded and repainted it. But I was not happy with the way it turned out so we bead blasted it.
[/IMG]
Allbutwet
Bell housing after bead blasting gasket area. The lock ring had some corrsion and with all the in's and out's I was glad I was able to bead blast it.
[/IMG]
Allbutwet
Look at what came today!
[/IMG]
But someone forgot to get the wrist pin bushings. Quess I will stop and get those tommorow. By the way here are the part numbers for the Items in the photo. Thease are the Ipdusa numbers that I crossed over. So far everthing looks right. If not I will let you know.
Piston set with rings .030 over: 110700(Correction I used ITM engine components pistons Part#RY2600-30)
Cam bearings standard : 101294
Main bearings standard :101293
Rod bearings standard : 101287
45MM freeze plug : 101299
42MM freze plug : 101301
Funny thing was when I first called they didn't have any parts for me. But after spending 8 hours researching and cross referencing I was able to get all of these through them. Power of the internet. Any how I hope this helps someone else. And just as a reminder mine is n AQ 130D with a AQ280 outdrive. As the tag pictured below shows.
[/IMG]
74bayliner
Same exact one i got! thanks allbutwet. i am ordering piston rings from them tomarrow as i do not need new pistons... im gonna have to take the block back to machine shop to bore 30 over...
and i will probably order new rod and main bearings for good measure and longer life for the engine.. thanks for these pictures.. keep us posted sir.
That transom shield came out beautifully!! i am taking two of my outdrive pieces to the Bead Blasting shop tommarow to see the results i will get with trying to paint them... I will post results so you can see if you are following my thread. i am enjoying this one....
maybe one summer day i will be in the Oregon area we should race our boats lol!! they would pretty much be equal except for mine is a 270 outdrive.
oops!
[/IMG]
geez thats pretty
sqbtr
What is your plan for repair of the tilt sealing suface boss?
74bayliner
yeah now that sqbtr mentions it .. it does look broken... (I broke my very first one off just like that because i didnt know the tilt mechanism disassembled at that Shaft/Lifting plate... so i just pulled it up and it snapped exactly like that...
But from what i have read in past posts i think that a Prop Shop can fix that...
can anyone confirm this?
glnbnz
I have gotten caught up on your rebuild thread and am following along now...looks great and I am looking forward to updates!!
Allbutwet
Sqbtr: What is your plan for repair of the tilt sealing suface boss?
Not sure yet. before I paint this time im going to install the tilt shaft into it and see what I have to work with. A po had globbed it up with clear silicone. If I can seal it from above; I will. Otherwise I might have to get creative. When I get back to it I will let you know what I did.
Allbutwet
Eye Candy!
Engine back from machine shop with over size bores.
[/IMG]
[/IMG]
[/IMG]
[/IMG]
New Cam bearings Installed
[/IMG]
Allbutwet
And after some paint.
[/IMG]
[/IMG]
Oil pan before
[/IMG]
And after
[/IMG]
Bell Housing before
[/IMG]
And after
[/IMG]
74bayliner
im jealous man!! i cant wait to close on my house so i can move all of my engine stuff into an open garage with more space to work on it!! but i like the progress! you will be running by summer :)
