Timguy
- May 1, 2011
- 60
Hi, this is an intermittent problem that turned permanent. Good compression and spark. Motor won't run above 2500 rpm. Even if I unplug the temp / rpm limiter. Checked wire back to controls from limiter sender and it is open.......any ideas? Stator, trigger, power pack, and coils all test good. Maybe a coil shorting out at higher rpm? But I've changed both coils 2x. Techs at Marine Engine.com think I'm a fool. I've got almost 400 posts at that site, I think I'm gonna give them up. Please help. Thanks, Timguy
