1977 35hp Johnson exhaust under the hood.
dfrants
my neighbor got a 1977 35hp Johnson that had been sitting for 2 years. when I run it in a test tank, exhaust fills up under the hood and chokes the motor out. any ideas what might cause this?
interalian
Blown powerhead gasket maybe? Maybe you could see it coming out with the hood off.
Chinewalker
Yep, you're running it in a test tank, that's what causes it. If the problem persists on a boat, then you have a problem, but in a test tank, a strong fan directly in front of the motor to blow exhaust out of the way is necessary.
