Now I'm Really perplexed!!! Just got my NEW Compression Checker (found out my B.I.L took the old one with him when he move to Virginia) I went out and checked all four cylinders and...#1 = 100psi, 2,3 & 4 = 105psi Not Great but...from what I've learned here on the forum well within running range. Haven't checked the spark yet. But, as stated before, it starts and runs great on the muffs. I DO have to spray some fuel in the fogging hole for the first start up, but after that she fires on the first bump usually. If it was an ignition or spark issue why would this change when she's in the water? Again, I'm just working on Logic here, and have NO mechanical skils other than what I've learned here on the forum. If I do get a good arc on the spark...Where else do I look. I can't imaging it's a carb issue cuz it would run bad on the muffs...Right??? I'm really bummed cuz I WANT to get on the water before COLD!!! I'm to much of a C.O.B to take it to a shop and spend $250 bucks for it.
But, maybe that's what it's gunna take.:noidea:
