VP46
- Jul 8, 2010
- 25
Hello iboat forums!
This is my first post so be gentle
I am the proud new owner of a 1976 Crestline Crusader 995 with a ford 302 and a merc 888.
It would seem that the previous owner (my father in-law) screwed the pooch and forgot?? or didn't properly winterize the boat. When I took possession (last week) a couple of problems presented themselves:
1. two of the 10 freeze plugs (core plugs right?) nearest the heads in the front were either out or were half way out.
2. there was an issue with stalling and restarting at low idol ( which is the least of my issues now)
I put the freeze plugs back in and worked on getting her started to begin to trouble shoot and hopefully solve the carb issue. Once I got her started she ran pretty darn smoothly at low idol and would cut out at higher rpm. I then looked at the oil breather tube and noticed it was spitting out a sickening froth - that of oil and water mixed. The oil/water froth was also coming from the oil check tube.
So.. my question?
Is it ....
A) a positive indication of a cracked block or cracked head or both
or
B) a blown head gasket
and finally
How do i confirm this?
Many thanks in advance!
So.. my question?
Is it ....
or
and finally
