1976 evinrude power pilot
smokincrow
Hello folks, i had the replace the ignition switch on my 1976 power pilot. when i took it apart there is a detent spring and ball bearing that came out.It seems to kinda lock the throttle in forward, neutral, or reverse. I replaced the ignition switch but cant figure out how to get the spring and ball back in place. Any advice would be much appreciated. THANKS
emdsapmgr
You may find the factory exploded parts diagram helpful at this website: epc.brp.com
bonz_d
There should have been a small metal plate covering the spring and ball, held in place by one screw.
