To make a long story short. In one motor I blew the coil for cyl 1 2 times. I moved everything to another motor and I blew the coil in cyl 2. Motor two came to me with cyl 2 blown. Before I went on the lake to test each time the motor was running great. Took it to the lake and it ran great. I would stop and fish for a little bit and restart. Sometimes I could do that a number of times. Feel pretty good about the job and then it would be hard to start. Then I would determine that a cyl was out.
The only difference between the two was the stator. I moved everything from one to the other. Including the trigger but not the stator. Could both stators be bad?
I was under the impression that the stator was not cylinder centric. It just feeds the power to terminal 1 of the power block. And the trigger signal determines where the power block sends the juice.
I have done all the CDI checks for the powerblock and coil packs. The last coil pack blew with a new powerblock.
Help me Mr. Wizard....
Mike
Mike
