1976 7.5hp mercury no fire
lbonura
My 7.5 mercury doesn't seem to have any spark. It's been sitting up for about a year.It was running up til then. I was having trouble with a toggle switch used as a kill switch before. Could this be my problem? Should I replace the toggle switch before I try anything else?
G
Guest
Guest
Re: 1976 7.5hp mercury no fire
you should disconnect it and see if that is causing it. I would check the points also
tpenfield
On my 1969 Merc 7.5 I found that the wires were fraying inside the small wiring harness and causing the ignition to short out. So, I would check the wiring to see how things look.
I do not believe there are points on a 1976 Mercury 7.5 HP
G
Guest
Guest
shows how much i know. (basically sharing info i have read on the forum from other people with similar problems)
