I have been working on a 1976 2 hp Evinrude. I have replaced the ignition system, the spark plug, spark plug wire, fuel line, fuel shut-off valve, impeller, and totally rebuilt the carb. The motor starts on the first pull but it will not go fast, in fact it has one speed, it will not go slow and it will not go fast, it wants to stay at the "Start" level. I tore the carb down again thinking there must be an obstruction but can't find one. I replaced the fuel filter/shut-off valve thinking that might be defective, but no improvement. I found out the cam was installed backwards, and I was SURE that was the problem. Again, no improvement.
I have a 1974 2 hp Evinrude which goes REALLY fast, and also REALLY slow, so I know it can be done. Compression on the 1976 is 90 psi which I understand is acceptable for this motor. I am stumped. Please advise. Thanks.
