swede44641, I have to say I think this is in your fuel delivery system and that would be in the three carbs. So maybe its time to buy carb kits and rebuild the three carbs on that engine. And make certain you get the proper carb kit for the two different types you have as well. The middle carb is slightly different then the upper and lower carbs. So buy the proper kits and remove them and disassembly them and clean them. If you haven't already bought the factory shop manual for your engine, I would highly suggest you buy the manufacturer's shop manual and follow their step by step carb works... JMHO!
