Re: 1975 johnson 115 hp.
cluke, could be any number of things...you really need a manual though. thats the best money you'll ever spend on your motor. If your not getting spark could be powerpacks...could be a coil...can you isolate the problem? Is if one plug?? one bank?? or all of them?? If one plug could be a coil..switch coils and see if the problem follows...if bank...switch powerpacks around see if problem follows. If all of them check all conections...WELL...get some terminal cleaner and spray in each of the connectors and make sure you are getting good contact. If none of that works you really need a manual and do all the electrical diagnosises that are in the book. They are really straight foward...only thing that you need that you may not is a DVA. You are in the right place..I know some more folks will chime in...they really helped me out when I was at the end of my rope...I did all the tests and replaced some parts...some of which needed it...some didn't..lol. Let us know what you find out.
