Re: 1975 70hp johnson stalling out
Jor593,
Yes, I would highly rebuild your carbs with brand new rebuild kits. When was the last time the carbs were rebuilt? If they haven't been rebuild I would do that now becuase your low/idle speed jets and passageways are probably clogged up. Also, when was the last time you replaced your waterpump impellar? If that hasn't been done do that also. The way I look at it is if you do the preventive maintenance now which is alot cheaper than a total rebuild becuase you didn't do the basic maintenance on it. Also, I would change out the lower leg unit gear lube and make sure you get new o-rings for both the upper and lower drain/vent screw. Take care, Bob
