This motor will run fine for a while and then just bog down at WOT. Then I have to play with the shifter level up and down until it kicks in again. It seems like it bogs down when I hit a big wave, maybe jarring something. Anyone know what could be causing this? I have had the carbs professionally cleaned, replaced fuel pump diaphragm, replaced fuel filter gaskets, fixed leak in fuel supply line, cleaned out distributor, new spark plugs, cleaned connections on switch box, and unplugged coil wire to clean.
Thanks!
Thanks!
