I think I know what to do to fix my problem but I want to get the opinions of some of this sights experts. This motor ran good on the muffs at home at idle and low speed for about 10 minutes. Went to the lake and it took a lot of choking and the cold start lever had to be up at the neutral point to get it to start. Then ran good until I got halfway across the lake. Then it stuttered and sputtered and died. It started a couple of times but died under load. It would not start and run after that.
I took the cover off and watched as my son tried to start it. It was then that I noticed the bottom carb leaking at a steady stream. When I squeezed the primer bulb it got worse and the middle carb began to leak as well. While leaning out the back I also noticed water and exhaust coming out of the square hole of the center tube?
So based on my limited boat experience, but better car knowledge, I would say the carbs need pulled and rebuilt, and the floats set. Bottom carb has a stuck float and probably dirt in the passages. Middle carb is going bad. Top may be ok, but best to do them all. Then run seafoam through the engine.
It has the single fuel pump on the side of the lower cover. Should I just go ahead and rebuild it while doing the fuel system? Should I worry about the exhaust and water coming out of the middle? I think I read a post where this was normal but could not find it today. I now await your expert advice and opinions as to if I am right or wrong and any points that I may also try in order to fix this motor. As always thank you for the help.
elark
elark
