WillemWallace
- Mar 2, 2011
- 34
I need to pull the flywheel on my 1974 4HP Johnson outboard. I have a Selco shop manual that shows removal on larger engines with a basic bolt into flywheel and tighten center bolt type puller. The problem is, the flywheel on my little 4HP does not seem to have any threaded holes on the top of the flywheel to bolt a puller to. Could someone who knows the correct way or type of tool I need please chime in. Any info is appreciated.
