Set the low speed needles at 1 1/4 turns out then run motor in F gear in water and turn them slowly in then out until motor runs smoothly then give them 1/4 out; motor should accelerate smoothly and idle around 600 rpm, if it still runs poorly you might have to set the float levels. If you get an alt tach connect it to one of the Yellow wires on the rectifier not the Red one.
