Well I've got my water pump replace and while going back together I didn't get the splines lined up on the shift linkage. Long story short I bent the shifter rod and now it wont line up to the lower unit. I looked at the shaft and can see a small pin on the top of the shift which attaches to the upper shift linkage in the power head. How do I get that little pin out. It looks like its pressed in and the only may be to drill it out. If that's the case it looks like I will have to remove the carbs and everything else to get inside there. Does anyone have a trick on how to get the shaft out or how to straighten it back out while still attached. I've tried pry bars to straighten it but with not much luck.
