Hi guys I got a 1973 johnson 50 HP 2 cylinder. Does anyone know what the compression is suppose to be? I have 80 PSI in one and 90 PSI in the other. I was thinking a blown head gasket reason being. Water pump was getting bad I changed it, then motor overheated, I then changed thermostat and relief valve I am not sure if its another bad thermostat? Doesnt seem to overheat everytime, so I thought maybe a blown head gasket?? The other day the water was warm coming out of the outlet today it was cold overheat alarm went off?? Anything would help thanks!!
