jmink
- Jan 27, 2014
- 64
Needing some wisdom from the iBoats gurus. Per my title of this thread I have a 1973 Evinrude 85hp model number 85393M and I have replaced the key switch, solenoid, and battery. With all of these changes, I still cannot get the motor to even attempt to crank. If I take a jumper and bypass the starting system by going from positive battery connection straight to starter positive terminal it will spin and try to crank.
I have also pulled the remote control apart to check on the neutral switch only to find the same results whey bypassing the switch.
One note is that when turning the key to the on position you can see the choke engage which tells me I am getting power to the motor.
I am a bit lost at this point and any guidance or ideas out there will be greatly appreciated.
