1973 25hp evinrude fuel pump
Evinrudemn
Well the problem with my pump is the diaphragm was shot trying to get a rebuild and local omc dealer said not a chance only a new pump do they make a kit or a pump that will work that's not 125
Step #1 is to take your pump apart.---Then lay out the parts.----Then compare pictures of parts in various repair kits.----Pick the repair kit that closly resembles your pump innards and has the correct diaphragm.-----Some parts you can throw away !!
Evinrudemn
Does anyone have a close up picture of the fuel pump on that motor I marked it how it came apart but am wondering if the previous owner had it apart before and put it back wrong thanks
Evinrudemn
Forgot that my father in law has a 1972 18hp went and looked at that and got it back together did the blow test and works right now to test it tommorrow
