I have a 1972 Mako with a 51-gallon aluminum tank that has 3 year old gas in it. I just bought a new motor to mount and know the the gas has got to go. Removing the tank from the hull and replacing it with a new one is not an option, due to the T-Top and Center Console mounting position. The only alternative is to clean the existing tank. I tried to siphon the 1/2 tank (20 gallons) of gas out but the siphon hose I was using kept getting clogged with "white sludge". I've read several threads discussing certain chemicals that can be used to clean out the sludge from DIESEL tanks, but this one is gas. Are there any "cost effective" solutions to remove the old gas and have the tank clean again? The boat is being worked on in the Beaumont, TX area, so if I need to have it professionally done, are there any marine shops that can handle this? The winds are going to die down eventually and I've got to get into the blue waters soon....PLEASE HELP !!!!<br /><br />Thanks,<br />Saltymut
