jason 1971
- Jan 23, 2012
- 25
Hello, just bought the motor yesterday. The guy fired it up in a tub of water, it idled fine, sounded good. He never revved it up or anything. He said it was a great motor, nothing wrong at all. I fired it up when i got home, and the tiller throttle didnt turn as much as i thought it would, probably only 60 degrees or so. with the top off you can see the advance or whatever the thing is under the flywheel turning good, but it seems like it should go farther. The little plastic bushing on the carb linkage that the advance is supposed to hit and make open the butterfly isnt being touched. So, when you turn the tiller all the way, it might be getting to 1000 rpms and the carb linkage isnt even opening. I can take my finger and do it and it revved up like i figured it should. Any help would be greatly appreciated. Thank you.
