Hello! I have a question about timing on this Johnson. I dont know that it is timed correctly and I just want to check it. Unfortunately I dont have a large enough test tank. I seen a post by Joe Reeves about timing without a tank or wheel simply by subtracting 4 Degrees on this post
http://forums.iboats.com/johnson-ev...set-wot-timing-without-test-wheel-428951.html My question is will this apply to my Motor as well? I just want to be sure it is timed correctly before I keep usuing it. I plan to go out this weekend again and use it all day after I put the proper carbs on it. (There was carbs from a 1972 125 HP Johnson on it and it cut out real bad at past Half Throttle I think it was way too rich)
And One other question how can I tell if this motor has the Quick start feature?
